Dave's RV-7A Builder's Log
Date:  2-28-2007
Brief Description:  Landing light installation
Began installing the landing light in the leading edge. The process is exactly the same as the left side, so there was a lot less to study before beginning. As before I opened the cutout with snips, then used a high-speed rotary cutter to finish the job. After filing the edges straight and smoothing with a ScotchBrite wheel, I marked and drilled all necessary holes. Next session will be the actual installation process.
Cutout marked
Cutout marked
Reinforcing brackets in place prior to drilling
