Dave's RV-7A Builder's Log
Date:  5-10-2006
Number of Hours:  1.00
Brief Description:  Fuel tank pressure check
Rigged up a manometer to test the fuel tank pressure. The Van's instructions recommend no more than 1 psi for the check, so there is very little pressure in the tank. After about an hour, the water level had dropped about an inch--this could be due to the air cooling, only time will tell.
Leak check underway
Leak check underway
