Dave's RV-7A Builder's Log
Date:  9-22-2016
Number of Hours:  3.00
Brief Description:  Brake lines and covers
Finished up the brake lines by adding two Adel clamps to support the lines and provide some rigidity to the assembly. Also spent some time working on the fuel pump and selector covers which needed some trimming to fit the new plumbing scheme. I ran into some challenges with the pump-to-firewall line where it drops down to run under the cover. For some reason the geometry, which fit perfectly before, is now causing interference with the cover. I trimmed the cover as much as I was comfortable with, but there still is contact, so I'll either have to trim more...or possible rebend the tubing to get it to drop down a little more.
