Dave's RV-7A Builder's Log
Date: 3-31-2007
Number of Hours: 4.00
Brief Description: Aileron & flap prep
Today I started by removing all of the blue plastic from the ribs, stiffeners, brackets, and gap seals for the ailerons and flaps. I had read that the longer the plastic remains on a part, the harder it is to remove...this is true! I guess you have a tradeoff...you can remove the plastic immediately upon receiving the shipment and take your chance with scratches, or you can wait until you use the part and work a little harder to remove the plastic. I think I'll stick with the latter.
After removing all of the plastic, I marked the aileron stiffeners with a sharpie and started cutting with the snips...suddenly I remembered the bandsaw that I had purchased for just such a purpose. The bandsaw made quick work of the cutting, and after a quick pass on the belt sander, I deburred all of them on the ScotchBrite wheel. I have to say that making stiffeners is not my favorite part of homebuilding.
Once the stiffeners were done, I used the ScotchBrite wheel in the bench grinder to work the edges of all the parts for the ailerons and flaps...this is a lot of parts! I finished by using my high-speed rotary tool with a small ScotchBrite wheel and worked all of the lightening holes in the long braces and gap seals. Next up will be fitting, match drilling, and assembly.
Cutting the aileron stiffeners
Aileron and flap components after working edges
