Dave's RV-7A Builder's Log
Date:  10-7-2017
Number of Hours:  8.00
Brief Description:  Misc finish work
This was the final weekend before my airworthiness inspection next Thursday. I still had quite a few things on my list to finish up, so I picked back up at the nose and worked on the backing plates to complete the spinner. Fortunately I had saved the pieces that were originally trimmed out when I made the main cuts, so I used those to make the backing plates. The contour gauge gave me a rough place to start, and with the bandsaw and Dremel I quickly got the pieces trimmed to final shape. After drilling the plates, I primed them and then riveted them onto the main hub.
After finishing up the spinner, I checked off a number of things on the list, to include:
• Installed the seat belts
• Checked and verified flap, aileron, elevator and rudder travel
• Final installed the alternate static switch
• Installed the battery retaining bracket
• Adjusted all of the cowling cam locks
• Lubricated all control bearings
• Added some zip ties to the magneto leads to secure them above the cylinder heads
Long day, but very productive. Tomorrow I will focus on fixing the brake leaks, finishing up the cowling work and hopefully get some avionics programming done.
Initial fitting of the backing plates, still needs some trimming to clear the prop
Backing plates installed
