More work on the baffles today, primarily finishing the fitting and trimming to allow the top cowling to fit properly. Once that was done, I started working on the tension rods, but quickly found out that threading stainless steel rod isn’t as easy as I had hoped. I will do a little research and come back to that.
With that left undone, I turned to the baffle fabric and started working on getting that installed. The pics show the right side done. So far this has been a lot easier than trimming the baffles.
