Dave's RV-7A Builder's Log
Date:  2-25-2006
Number of Hours:  4.00
Brief Description:  Left wing leading edge
Had to remove the leading edge to ensure all holes were aligned properly prior to final drilling. After reinstalling the leading edge, I added a bracket to the lower section of the wing stand to keep the wing more stabilized. Following this, I fabricated the fuel tank to leading edge joint plate, then positioned it and final drilled the skin to the joint plate and inboard rib. I now have to final drill the remaining rivet holes in the leading edge, then on to the fuel tanks.
Inboard rib fitted and drilled
Lower side detail showing joint plate and tiedown hole
