Air Camper Construction Log
Date:  4-5-2014
Number of Hours:  1.50
Brief Description:  The Return of Spring
It appears that spring has returned… longer and warmer days will hopefully translate to more work in the hangar. I reinstalled the tail surfaces in the hoped that I’ll find time to start cutting some cables and getting things rigged. I also need to fabricate the diagonal wing brace tubes as I currently have a pine 1x2 holding the wing from shifting back.
