Air Camper Construction Log
Date:  10-5-2012
Brief Description:  Elevator Bellcrank Bushings
I wasn't real happy with the plans built steel bushings for the elevator bellcrank. I had a couple of big hunks of ABS plastic that I cut to replace the original parts. Not only should the offer long wear, but shouldn't require much, if any lubrication.
ABS Bellcrank Bushings
