Air Camper Construction Log
NX762R
Engine Overhaul
Removed heads. Several of the head studs pulled out of the case without too much effort (they are not supposed to do that). I found a hole punched in one of the pistons (#5 I think) and one of the rockers was loose and rotated on the same cylinder.
Fighting Rusty Studs
Heads Off
Hole In Top (left) Piston
NX762R Home
1506
Cables and Control
Covering
Electric/Instruments
Metal Fabrication
76
176
Shop Prep
435
