Air Camper Construction Log
Date:  5-28-2009
Brief Description:  Urethane - 2nd Coat
After rereading the section on woodes wing ribs in Tony Bengali's book "Sportplane Builder", I found that he recommends at least two coats of varnish or urethane. Even though mine seemed to be pretty well coated, I decided to give them a light sanding with a 150 grit foam pad and apply a second coat.
