Air Camper Construction Log
Date:  3-24-2009
Brief Description:  Shaping Capstrip
I finally received my capstrip today, so I was able to get on with shaping a few pieces. Rather than set up some elaborate steam system, I chose to construct the cap strip soaker from the Tony Bingelis article “Making Wood Wing Ribs” – Sport Aviation – 2/94. Once that was constructed, all I needed to do was boil a pot of water and pour it in, which I was able to do in the kitchen since it was a small and quick project. I built two forms from 2x6s that will accommodate 3 strips each, so I was able to soak 6 strips total in the first batch. I wasn’t sure how long to soak 1/4” x 1/2" strip, but I left these in for at least 20 minutes and they seemed to bend just fine. Once they were clamped to the form I placed them out of the way to dry for at least 24 hours. I think I will cut several notches in the forms with the band saw prior to the next run, which should ensure that the strips (especially the center) dry thoroughly.
Soaking
Soaking
Bent To Form
Bent To Form
Three Per Form
Three Per Form
