Air Camper Construction Log
NX762R
Primer Coat
Applied primer to wing using the same method as the control surfaces. Two coats applied with a 3” foam brush, wet sanded with 100 grit sandpaper, then two finish coats.
NX762R Home
1506
Cables and Control
Covering
Electric/Instruments
Metal Fabrication
76
176
Shop Prep
435
