JOSEPH'S WEB SITE
Date:  5-9-2011
Number of Hours:  10.00
Manual Reference:  DWG 3
Brief Description:  Horizontal Stabilizer
HS-609PP riveted to HS-603PP using rivet gun.
HS-412PP & HS-413PP hinge brackets riveted to rear spar.
HS-411PP bolted to spar and torqued to 25 inch pounds.
HS-710 & HS-714 riveted to HS-702 front spars. The center 4 rivets were flush.
HS-404 & HS-405 riveted to front spar assembly.
Left -
HS-707 riveted to top side of HS-601PP
HS-706 clecoed to HS-601PP.
HS-708 clecoed to HS-601PP & HS-707.
HS-707 riveted to bottom side of HS-601PP.
HS-708 removed.
Forward spar assembly clecoed to HS-706, HS-707 & HS-601PP.
HS-708 clecoed in place.
HS-702, HS-707, & HS-708 blind riveted together.
HS-702 riveted to HS-706.
HS-702 & HS-708 riveted to HS-601PP.
Right -
HS-708 removed.
Rear spar assembly clecoed in place.
Top of rear spar assembly, HS-404, HS-405, & HS-706 riveted to HS-601PP.
