JOSEPH'S WEB SITE
Date: 5-5-2011
Number of Hours: 6.00
Manual Reference: DWG 3
Brief Description: Horizontal Stabilizer
All ribs marked for left or right side. Hole locations on forward flange of HS-405 located, marked and drilled to #40. Left side HS-702, HS-603PP, HS-706, HS-707 & HS-708 clecoed together. All rib to spar holes, except HS-708, drilled to #30. Everything un-clecoed, deburred, and re-clecoed. HS-601PP clecoed on. HS-708 to HS-603PP holes enlarged to #21. HS-404 & HS-405 ribs added, hole locations marked using skin, then removed and fluted. Centerline marked on HS-404 & HS-405 ribs. Ribs then put back into assembly. HS-405 aft flange drilled to #30 and clecoed to HS-603, then removed and chips cleaned out. HS-405 re-clecoed to HS-603 and clamped to HS-601PP. HS-405 drilled to #40 using HS-601PP as a guide starting from the rear. HS-702 drilled to #40 using HS-601PP as a guide from inboard to outboard. HS-710 & HS-714 clecoed to assembly. HS-405 to HS-702 to HS-710 & HS-714 to HS-404 drilled to #30. HS-404 re-clamped to HS-601PP. All the remaing holes on HS-601PP match drilled to underlying assembly using #40 drill. HS-601PP removed. Outboard 3 holes of HS-710 & HS-714 drilled to HS-702 using #30 drill then removed. Parts marked and disassembled.
