Brief Description: Avionic layout, Water pump change.
Lower LH water pump inlet replaced with a 90 degree pipe ordered from Rotax. This stops the hose rubbing on the mount. Exhaust and various pipes removed for access. Throttle grips arrived, and have been test fitted. One each side, relaay will be used to allow both to drive the elevator trim. Avionics layed out onto panel. Additional box designed to sit under centre panel to hold the EXP TRAY.
