While waiting for proseal to cure I did a number of small items over servera days: Assembled and installed bell cranks. For the right bell crank I had to turn the brass bushing in the drill press with brown scotch bright to eliminate binding that occurred when I setting it in the bell crank tub. (Estimated time – 2 hours) Fit and riveted ends to control rods – 2.5 hours. Fabricated stops for right and left aileron – 1.5 hours. Fit right aileron stop - .5 hours. Fit right aileron to wing – 1 hour. Total estimated time – 7.5 hours.
