Brief Description: Flap and ailerons brackets - right wing
Over severa sessiosns: Match drilled and riveted aileron hinge brackets to right rear spar (prevooiusly assmbled and revited hinge bracket components togehter at the same time I did the brackets for the left spar. Fit the flap hinge brakets to spar and ribs and back drilled ribs. Riveted brackets to ribs, Fit the W-925C and W-925As support angle braces. drilled rivet holes using holes in spar and ribs as guides. Drilled skin to W-925C holes using holes in bottom skin as guide. Machine counter sunk holes. Deberred and primed using zinc chromate primer. Riveted in place brackets in place.
