Brief Description: Various wing work; riveting skins
Piimed area of inner skin that is overlapped by outer skin. Did not prime this when I primed the inside surface. Completed clecoing skins to skeleton. Check alignement with plumb bobs. Both ends measured same distance from plumb line to rear spar. Inserted rivets and taped in place for riveting with back riveting in mind. Decided to rivet from front and had Teryl, my wife buck from behind. Now that I have learned to set the rivets with a soft, two to three second stroke, I had no concerns about possibly deforming the skin as I set the rivets. Completed the first set of rivets on inner skin. Turned out very good, at least as good as the back riveting effort on the left wing skins. Also spent time setting up the right landing light mounting bracket.
