Brief Description: Rivet right leading edge to spar
Prepared to rivet leading edge to spar. Clecoed leading edge to spar and fit fuel tank to spar to make sure I had a good fit between leading edge skin and tank skin. On the left wing, I had to shim the leading edge skin to match up against the tank skin, probably because I used to high a pressure on the rivet gun and deformed the leading edge rib and splice plate. After testing the fit, which was OK, removed the than and riveted the than ribs to the main spar web with the help of a friend. I bucked and he drove the rivets.
