Brief Description: Rivet leading edge and prepare to rivet top skins
Riveted leading edge to spar. Attached tank to spar per instructions using half of the screws and bolts. Initially I attached tank with screws first only to fine that the z-bracket holes and the holes in the spar web did not line up. After removing screws, I was able to line up holes and set half for the bolts that attached the tank to the spar web. Clecoed top skins and inserted rives and taped with back rivet tap preparing to back rivet top skins. Completed about half of the back rivet set-up. Checked alignment to assure that there is no twist developing. Will make a final check before I set the rivets.
