Brief Description: Cleco and match drill right stabliizer skin
Clecoed and match drilled and deburred left stabilize skin. When fitting the ribs, I found that the holes that I match drilled in the front spare and rib flanges did not match up when is clecoed the ribs to the skin. I tweaked the rigs a bit and clecoed the ribs to the spare and then to the skin eventually getting everything to fit. I did not observe this problem with the right stabilizer. The same problem probably occurred. I expect that this will not pose a problem when I assemble and rivet. We'll see. The new compressor works great.
