Deburred and rounded edges of F-705 bulk head parts. Fabricated F-705J, F-705Ks, F-705L, and F-705Hs. Left fabrication of F-705Cs to be done after fitting and drilling. Cut F-705B Center Section Bar to size and fit to F-705A rear spar attach bulkhead. Drilled two holes using F-705A as guide to hold the Center Section Bar in place while fitting the F-705Bs and F-605Cs. Fit the left F-705B and F-705C and back drilled using the F-705A as guide. Did this in several steps to assure a square hole through the F-705B, F-705C and F-705H spacer. First drilled through to F-705B marking the position of the hole and then completed hole on drill press. Reassembled with space back in place and repeated operation on spacer and then put space back in place and completed drilling through F-705C.
