Fuel sender: Another thing quicker and easier than the first time... or so I thought. Bent the wire, used the plexi I used on the other wing to check it out (just had to flip it over), and a problem... the float runs right into the stiffener on the bottom of the tank. Lot's of head scratching, but I'm not sure what I did wrong...
Wing is upside down, so I'm lifting the float to the bottom of the wing, where it runs into the stiffener.
