JASE'S WEB SITE
Date:  5-27-2007
Number of Hours:  6.00
Brief Description:  Wiring Conduit
Wiring Conduit: What a job. I ended up getting a 12" drill extension, and then had to rig it up with additional socket extensions in order to get all the holes drilled in the ribs for the conduit. Pulling the conduit through is a bear as well. The hole is sized for the "inside" diameter of the corrogations, so it doesn't pull through easily. It isn't coming out, that's for sure. Got it done, and put RTV where it meets the ribs to keep vibration from wearing through it.
