Bellcrank, Fwd top skin: Fabbed up the spacers and fitted the elevator bell crank, and started (just started) fitting the forward top skin of the rear fuselage. I also decided to take apart the other brake pedal and prime it.
The elevator bell crank. I should have taken the picture when I had it in the fuselage!
Primed the second brake pedal.
Fitting the top skin. Van's had pop riveted two triangular pieces of sheet on the tangs extending forward from the overhead J c
