Brief Description: Seat back adj and control column plus other stuff.
Seat back adj and control column plus other stuff: Took a lot of time to not do a whole lot. Bolting the control column stuff together was, I thought, a ten minute task, that literally turned into hours. The brass bushing was too small for the bolt (found out from surfing VAF that I needed to drill it out, after I got the bolt stuck trying to "persude" it in), and there was a lot of grinding and fitting to get it all to work right. I got the seat back adjustment parts ready to rivet, which I'll do tomorrow or the next day.
