Rudder: More difficult than the stabs. Several drilled out rivets in this engagement. Made the mistake of not trimming the corners off the leading edges of the stiffeners, and then they interfered with the spar when closing. Was relatively quick to fix, but did cost some time.
Spar shot where you can see the lovely green rattle can primer I used.
Rudder skeleton. There really isn't much to it, and the skins used here are so thin (0.016) that it makes for a light assembly.
