I chose to use velcro to attach the laminated registration to the seat back. I also decided to drill 2 holes into the rudder pulley brackets and add safety wire. This prevents the cable from going outside the wheel well, which would be catastrophic. If however the cable popped off the pulley and onto the shaft, it's absolutely no problem.
