In order for these fuel tanks to slide into the rear set of lightening holes I had to file away some material from the 2 ribs nearest the wing root on both wings. The filing took about 1 hour per wing. I used the hydraulic knockout to create a 3" hole centered around the fill port of each tank. I will design a fuel tank door. The rubber gaskets will arrive next week.
