Today I completed the fabrication of 4 parts for the rear doors. The 2024-T3 0.063 sheet metal I ordered arrived today, so without delay I began fabricating the reinforcement plates for the lower rear door areas. I also fabricated out of 6061-T6 the angle aluminum that rivets to top of each reinforcement plate. In the third picture you can see the additional 2 reinforcement plates I will be cutting out for each side. Additionally, 2 brackets for each side still need to be cut out similar to PF-198 brackets for the front door area,
