I drilled and cleco'd the (3) PA-14 brackets that support the turtle deck. I crawled underneath and drilled while Xin put in the cleco's. It took 90 minutes to measure twice and drill once all the holes for the PF-190 and PF-191 wing root covers. Prior to drilling I had to use my deburring wheel to adjust the edges of both PF-190 and PF-191 by roughly 1 degree so that they would fit between the wing root brackets PF-143, this took about 30 minutes.
I also learned that the PF-155 (which is really A-08), which mounts to the instrument panel, is actually the same part as the guides that go between the bulkheads. It turns out this along with the PF-197 PF-201 and PF-205 parts that are missing are for the throttle linkage on a piston engine. Since I plan to be using a turbo prop, which uses a FADEC controller, these parts will not be installed.
