Fabricated the last reinforcement plate for the left side cabin, there are 3 for each side. I am using the table saw with the composite blade to cut these from now on. This is 6061-T6 because it requires a 90 degree bend and the 2024 would fatigue. I will probably add (2) 1/8" brackets around the rear door frame area.
