I found this picture of a bushcaddy modified to have an additional rear door yesterday and decided to give this idea some thought. So, recognizing this would probably end up adding an additional 100 hours of work and within the spirit of building an experimental aircraft I decided to go for it. I drilled out the 12 rivets holding the cross member on each cabin frame in place. Why have one rear door when you can have 2 for twice the labor! I cut out some reinforcement plates to rivet to the existing holes and strengthen the frame in those areas. I will also add a reinforcement similar the one at the base of the front doors. You can see the part I removed laying on the floor.
