JOHN'S WEB SITE
Date: 1-7-2015
Number of Hours: 1.50
Manual Reference: 2-2
Brief Description: Test fit of skin on V-Stab
I test fitted the skin that was previously drilled, dimpled, and deburred years ago. Everything fit together very well. I was most concerned that, when I drill out the rivets where the ProSeal delaminated as per Skeeter, will it still be aligned with the skin after I re-rivet. After doing this test fit, I believe that should I get something a little off (like 1/32 of an inch), that the rib will align itself anyway because the aluminum is free to twist slighty under the skin.
Clecoed VS7, VS1, VS4, VS2
Closeup of lower rib, VS4
