JAMES'S WEB SITE
RV-14A
prep items as of 5 June 2016
1. Go over 100% of the plane and look for loose nuts. Tighten those and use a “marker” (order from Aircraft Spruce) to show tightness
2. Get with Van’s about the elevator trim tab arm: Can’t get any nose up trim (emailed Joe Blank on 6/5)
3. Get with Van’s about the auto pilot servo “arms” (emailed Joe Blank on 6/5)
4. Find out about how the wiring for the wig wag lights is supposed to work. There is one wire (from Advanced)
5. Find out how to wire the defrost fans (from Advanced)
RV-14A Home
Avionics & wiring
Control Stick/System
Finish kit/actions
Firewall forward
Weight & Balance
