JAMES'S WEB SITE
Date: 6-21-2016
Number of Hours: 60.00
Brief Description: Amateur built 2016 checklist
Compile checklist items for Keith Sierks toward certification
1. Application for certificate of airworthiness 8130-6
2. Program letter
3. Copy of registration
4. Notarized builders eligibility statement on FAA form 8130-12
5. Conditional inspection filled out and signed
6. Equipment list include Item weight, arm and part number
7. Weighing of aircraft with CG calcs for Empty weight
8. Weight and balance examples at most fwd limit, most aft, and first flight( use reasonable weights to make limits)
9. Altimeter/transponder check as per 91.411 , 91.413 if required
10. ELT sign off of test as per 91.209 D
11. Record in AIRFRAME logbook. The following.. A) Install of engine/prop by make model serial number B) Builders statement C) Fuel flow test 23.955 D) Max power static run up. Mp/rpm or just rpm E) Conditional inspection sign off
I need items 1/2/3 to begin process with FAA. Coordination now requires contact and approval from 2 offices.
Make sure builders log up to date
Make sure program letter indicates if you want night, ifr, acro.
Aircraft must be complete and ready to fly with the exception of inspection panels, cowlings and fairings removed for inspection.
All placards installed (Amateur built, N number, Experimental) All switches , CB’s, fuel valves and fillers to be labeled.
Need copy of Amateur built and flight testing Advisory Circulars in your access
