Jim's RV12 Build
Date:  7-26-2014
Manual Reference:  12-10
Brief Description:  Tailcone
Steps 1-7
Locate and attach nut plates to designated locations on the tailcone assembly for tailcone fairing attachment.
Nut plates attached
Nut plates attached
Tapped the designated nut plate per instructions in Step 3
Located hole in lower tailcone fairing per Step 7.  After fitting, needed to elongate hole 1/2
Located hole in lower tailcone fairing per Step 7. After fitting, needed to elongate hole 1/2"
