Brief Description: Clecoed the front and rear spars
Clecoed the front two spars (HS902) to the spar doubler plate (HS907) and match drilled with #30 drill bit. Clecoed the rear two spars (HS903) to the rear spar doubler plate (HS906) and match drilled with #30 drill bit. Clecoed the eight (8) outboard hinge brackets to rear spar sub-assembly and match drilled with #30 drill bit. Started prefabricating the HS908 L/R
