installed resistors for p lead tach sensors wired and installed ignition switch fabricated and installed engine pressure transducer manifold fabricated and installed comm antenna cables fabricated and installed nav antenna cable installed and connected fuel flow sensor leads connected boost pump and boost pump light leads connected manifold pressure sensor wires installed and connected aileron trim servo including wiring
