installed, soldered, and completely wired all warning/annunciator lights installed ,soldered and wired Autopilot power switch and AP disconnect switch installed ,soldered, and wired rear PTT switch installed, soldered and wired smoke pump switch installed and connected aileron and elevator servo buss installed and wired fwd baggage accessory outlet to a 5 amp CB connected HOT to the battery with16 gauge wire installed all wiring for interior lights
