JON'S WEB SITE
Date:  1-24-2011
Number of Hours:  9.50
Brief Description:  landing gear
Aligned gear legs to be parallel to each other and perpendicular to fuselage longitudinal centerline
drilled all remaing gear attach holes
torqued all gear bolts
measured gap on attach brackets
gaps were .010 inches, required gap is .030
outboard attach brackets will need to be "machined" down and addtional .020 inches
removed landing gear
returned fuselage to upright position and attached construction legs to "false'"spars
Aligning gear legs
Aligning gear legs
brackets require
brackets require "machining"
ready for finishing
ready for finishing
