drilled, deburred, dimpled flap brace both wings drilled, deburred flap hinge riveted flap brace and flap hinge removed hinge eyelets in hinges to facilitate hinge pin removal modified single honge pins into double hinge pins drilled, deburred, dimpled and riveted aileron gap fairings dimpled remaining nutplate holes for aileron bellcrank access opening riveted remaining nutplates
