drilled wing ribs for pitot and AOA lines installed snap bushings for above lines drilled wings for wire run snap bushings installed snap bushings installed 14# wire in both wings for landing lights installed 18# wire in both wings for Nav lights installed 18# wire for strobe lights in both wings installed 14# wire in left wing for pitot heat Installed 18# wire in left wing for pitot heat status wire installed RG400 coax in left wing for VOR antenna in tip installed 18# wire in left wing for stall warning installed autopilot harness in rt wing installed green pitot line in left wing
