Aligned gear legs to be parallel to each other and perpendicular to fuselage longitudinal centerline drilled all remaing gear attach holes torqued all gear bolts measured gap on attach brackets gaps were .010 inches, required gap is .030 outboard attach brackets will need to be "machined" down and addtional .020 inches removed landing gear returned fuselage to upright position and attached construction legs to "false'"spars
