RV-8 N605TT
Date:  4-1-2007
Number of Hours:  1.00
Brief Description:  compressor maintenance
found water in the compressor lines today. i had installed an auto drain valve in the bottom of the compressor that is supposed to drain any condensation with each cycle of the compressor. doesn't seem to be working. it's a cheap accessory from harbor freight tools. i rechecked all the fittings and found some loose so i'll give it a week or so and see how it works now.
