drilled fwd HS to VS attachment point. per the plans, i had to adjust the location of the mouting plate and the spacer, but it seems to have worked out well. everything looks aligned at the cleco and "loosely" bolted stage. hope the final rivets and torqued bolts keep this same alignment, i might end up with a straight flying airplane.
