Mostly finished up the instrument panel access door. Match drilled, deburred, dimpled all the parts. Need to prime, install nutplates, and then ready for rivet.
Worked some more on the throttle quad mod. Will need a lower mount for support. Will most likely use some angle riveted to the F804 channel bolted to some angle riveted to the quadrant mount.
