Spent some time studying the pitot-static system. Drilled #30 hole for static ports, which are just pop rivets with the mandrels drilled out. Deburred and primed the holes. Will wait to install the pop rivets once I do the whole static system.
Also removed the F821 fwd, top skin and F803 inst panel subassembly for debur and dimple. Ended up not getting to the top skin.
Cut doubler strips for the instrument access door modification to the F866 bulkhead. Thinking of adding angle for stiffeners in the door, will follow up with the door installed.
