RV-8 N605TT
Date: 8-6-2006
Number of Hours: 3.00
Brief Description: primed hs skeleton
first attempt at priming. mixed results, but progress is progress.
first, cleaned the spray gun since it had oil throughout. sprayed a 1/4 container denaturated alcohol through it and cleaned internal parts.
second, wiped all parts with denaturated alcohol to removed oils, grease, part # label adhesives, finger prints/oils, etc.
next, mixed variprime 615s and 616s 1:1 as advertised by manufacturer. loaded up spray gun and practiced on some scrap. results seemed ok so i hit the actual parts.
the gun doesn't seem to shoot very well unless i shake it side-to-side while spraying. don't think it should require that. also, the gun seems to surge at times, causing the primer to go extra thick and run in places.
overall, i was getting the hang of it. i'll get jere to check it out and tell me if i'm on the right track.
Tanner decided to stop by and check on Daddy's progress. He's my QA guy...
Copyright © 2001-2020 Matronics. All Rights Reserved. |
